CNC 1.6 Pitch 3 Blade Cleaver Prop, Magnalium 7075 propeller. The 50mm size comes in either Red or Silver. Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Specifications:
Pitch ratio: 1.6
Blades: 3
Material: Magnalium 7075 alloy
Mounting & Shaft Size: 3/16" (4.75mm) Drive dog.
Rotation: Clockwise. ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
