CNC 1.4 Series Props : 4mm bore : 40 to 45mm
Product ID cnc-xx14250-4mm
Price: $19.95
CNC Magnalium 7075 propeller for 4mm prop shaft.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 1.4 Pitch 2-Blade 4mm Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
4014250-4mm40mm (1.57")56.02.204 mm
4214250-4mm42mm (1.65")58.82.314 mm
4514250-4mm45mm (1.77")63.02.484 mm
Specifications:
  • Pitch ratio: 1.4
  • Blades: 2
  • Material: Magnalium 7075 alloy
  • Mounting & Shaft Size: 4 mm drive dog.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
