Magnalium 7075 propeller. These are great all-around props, with great performance and runtime, and a good balance of top speed and takeoff speed out of the whole Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Material: CNC Machined Magnalium 7075Rotation: Left-hand (counterclockwise when viewed from behind the boat)Nominal Pitch Ratio: 1.4Drive Shaft: 1/8", 3/16", or 1/4" depending on propeller size
