CNC 3 Blade Prop : 32 to 70mm
Product ID cnc-xx14350
Price: $24.95
3 Blade Magnalium 7075 propeller.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 1.4 Pitch 3-Blade Magnalium Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-321435032 mm (1.26")44.71.761/8"
cnc-361435036 mm (1.42")50.51.991/8"
cnc-381435038 mm (1.50")53.32.103/16"
cnc-401435040 mm (1.57")56.12.213/16"
cnc-421435042 mm (1.65")58.72.313/16"
cnc-441435044 mm (1.73")61.52.423/16"
cnc-461435046 mm (1.81")64.52.543/16"
cnc-481435048 mm (1.89")67.32.653/16"
cnc-501435050 mm (1.97")70.12.763/16"
cnc-521435052 mm (2.05")72.82.873/16"
cnc-591435059 mm (2.32")82.63.253/16"
cnc-611435061 mm (2.40")85.33.361/4"
cnc-6314350-H63 mm (2.48")88.13.471/4"
cnc-6614350-H66 mm (2.60")92.53.641/4"
cnc-681435068 mm (2.68")95.03.741/4"
cnc-701435070 mm (2.76")98.03.861/4"
 Specifications:
  • Pitch ratio: 1.4
  • Blades: 3
  • Material:  Magnalium 7075 alloy
  • H = Hard oxygen-anodized coating for added strength.
  • Mounting: 1/8 ", 3/16", or 1/4" Drive dog, depending on the prop size.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
« Previous | Next »
CNC 3 Blade Prop : Reversed Rotation : 36 to 66mm
Product ID cnc-xx14350-R
Price$24.95
