CNC Prop : 3 BLD Reversed
Product ID cnc-xx14350-R
Price: $24.95
Reversed 3 Blade Magnalium 7075 propeller.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 1.4 Pitch 3-Blade Propeller Size Chart
Part NumberDiameter (mm / in)Pitch RatioPitch (mm)Pitch (in)Drive Shaft
cnc-3614350-R36 mm (1.42")1.450.51.991/8"
cnc-3814350-R38 mm (1.50")1.453.32.103/16"
cnc-4014350-R40 mm (1.57")1.456.12.213/16"
cnc-4214350-R42 mm (1.65")1.458.72.313/16"
cnc-4414350-R44 mm (1.73")1.461.52.423/16"
cnc-4614350-R46 mm (1.81")1.464.52.543/16"
cnc-4814350-R48 mm (1.89")1.467.32.653/16"
cnc-5014350-R50 mm (1.97")1.470.12.763/16"
 Specifications:
  • Pitch ratio: 1.4
  • Blades: 3
  • Material:  Magnalium 7075 alloy
  • Mounting: Drive dog
  • Rotation: Counterclockwise. ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
