Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
Product ID hh-817
In Stock 8
List Price: $3.65
Price: $3.49
These are 4-40 Safety Lock Kwik-Link Clevis' from Dubro.
Used to connect to a servo horn.
FEATURES:
Self tapping design leaves no slop on the pushrod threads.
Square nylon shank for easy installation and adjustment.
10% lighter than a steel clevis.
Brass plated stepped steel pin does not bind on control horns and has a large flat head for easy removal.
Brass plated steel safety lock slides into a groove on the pin for a
Secure and solid lock.
Safety lock is mounted in a track system on the clevis body to help prevent it from being lost.
INCLUDES: Two 4-40 Safety Lock Kwik-Link Clevis'
REQUIRES:
4-40 Pushrods of modeler's choice
SPECS:
Length: 1-1/8" (approx 28.5mm)
Width:       5/16" (approx 8mm)
NOTE: Servo in pictures not included!
Dual Arm Control Horn for Large Speedmaster Rudders 40/60
Product ID ros-spdr-018-da
Price$15.99
Dual Arm Control Horn for Small Speedmaster Rudders
Product ID ros-spdrs-002-ch
Price$15.25
Speedmaster 21 Rudder Assembly w/ Short Tee Bracket
1 of 2
Product ID ros-spdrs-006-21
Price$54.99
Speedmaster 21 Rudder Assembly w/ Extended Tee Bracket
1 of 3
Product ID ros-spdrs-009-21
Price$59.99
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
Du-Bro 518 4-40 Pull-Pull System
Product ID hh-518
Price$12.99
Scale Outboard with Metal Lower Unit: All Black
1 of 3
Product ID bel-2041-alu
Price$199.99
Prather 4-40 Radio Box Seals
Product ID hpi-pra8112
Price$9.99
SpeedMaster small inline skeg strut and single pickup rudder assembly
1 of 3
Product ID ros-spdrs-002a-sng-2
Price$89.95
SpeedMaster small inline skeg strut and dual pickup rudder assembly
1 of 2
Product ID ros-spdrs-002a-du-2
Price$89.99
Speedmaster Small Dual Pickup Rudder Assembly w/ Short Bracket
Product ID ros-spdrs-006-du
Price$47.95
Speedmaster Small Single Pickup Rudder Assembly w/ Short Bracket
Product ID ros-spdrs-006-sng
Price$45.95
Speedmaster Small Dual Pickup Rudder Assembly w/ Extended Bracket
1 of 4
Product ID ros-spdrs-009-du
Price$52.95
Speedmaster 40 Rudder Assembly
1 of 2
Product ID ros-spdr-010
Price$39.95
Speedmaster 1" Rudder Assembly
1 of 2
Product ID ros-spdr-013
Price$44.95
Speedmaster Dual Pickup Tapered Rudder Assembly
Product ID ros-spdr-011a
Price$49.95
Speedmaster Dual Pickup Straight Blade Rudder Assembly
1 of 4
Product ID ros-spdr-012
Price$49.95
Speedmaster Center Mount Dual Pickup Tapered Blade
1 of 3
Product ID ros-spdr-011a-60sb-tee
Price$49.95
Speedmaster Center Mount Dual Pickup Straight Blade
1 of 3
Product ID ros-spdr-012-dusb-tee
Price$49.95
