K&S Brass Tubing 36" long (915mm)
Product ID ks-brass-tb-36
Price: $7.99
K&S Brass Tubing, 36" (approx. 914 mm) in length. Sizes are listed in outside diameter (OD).
This tubing is used when building a stuffing tube system in a boat. There are two traditional ways to build a stuffing tube using a flex cable: either with a Teflon liner installed in the brass tube or without a Teflon liner. If you search online, you will find pros and cons to both solutions.
 K&S Brass Stuffing Tube Reference Size Chart - 36" (914mm)
Flex Cable SizeWithout TeflonWith Teflon
.150" (3.81mm)—1149 - 1/4"
3/16" (4.75mm)1149 - 1/4"1150 - 9/32"
1/4" (6.37mm)1151 - 5/16"1152 - 11/32"
Note: All brass tubing sizes refer to outside diameter (OD). Teflon liners are sold separately. A dash indicates no specified recommendation.
Notes:
  • All brass tubing sizes refer to outside diameter (OD).
  • Tubing is sold in individual 36" (914mm) lengths.
  • Teflon liners are sold separately.
  • Pictures 2 & 3 are for reference only.
  • Tubing will telescope into the next larger or smaller size. This is useful for making bushings, sleeves, or drive shafts. See pictures 2 & 3.
  • Loctite sleeve retainer glue is recommended for gluing brass tubing together.
Speedmaster Large 1/4" (.250) Strut
Product ID ros-spds-008
Price$29.95
TFL 1/4 Drive
1 of 4
Product ID tfl-503b98
Price$79.99
TFL 1/4 Inch Drive with skeg
1 of 4
Product ID tfl-503b98-a
Price$79.99
TFL Arenson Outdrive with 1/4 (6.35mm) Prop Shaft
1 of 4
Product ID tfl-523b43
Price$249.99
High performance Sevan Outboard
1 of 5
Product ID bel-flex-2042
Price$169.99
Cable alignement T bar for Zenoha Engines
1 of 5
Product ID tfl-526b36
Price$48.99
Speedmaster 1/4" CAT: Extended Strut Assembly: Flat Bottom
Product ID ros-SPDS-012-250F
Price$38.95
Speedmaster 1/4" CAT: Extended Strut Assembly: Round Bottom
Product ID ros-SPDS-012-250R
Price$38.95
Large Offset Catamaran Strut and Rudder System
1 of 4
Product ID tfl-502b36
Price$69.99
3/16 (4.75mm) Strut for Large Offset Catamaran Strut System
1 of 3
Product ID tfl-502b36-a
Price$14.99
Speedmaster Cat Skeg Strut Assembly - Small
1 of 2
Product ID ros-spds-017-SK
Price$34.95
Speedmaster 1/4" Gas Strut and Square drive cable system
1 of 4
Product ID ros-SPDSD2-G250
Price$159.95
OSE .187 (3/16") cable : drive dog : bullet nut : 3/16" prop shaft : 3.25" long
Product ID ose-cable-187-XL
Price$39.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Aluminum Tubing 12" long (305mm)
1 of 3
Product ID ks-aluminum-tb-12
Price$0.99
K&S Stainless Tubing 12" long (305mm)
Product ID ks-stainless-tb-12
Price$3.50
OSE 1/4" cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290
Price$34.99
OSE 1/4" reversed (right) cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290-rev
Price$34.99
Strut for 45 Inch (1150mm) catamaran 140mm long
1 of 3
Product ID tfl-503b85
Price$59.95
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
Teflon Liner 20 Foot bulk package (600cm)
Product ID oct-teflon-240
Price$39.99
1/4 Adjustable Stinger Strut
1 of 6
Product ID tfl-503b82
Price$46.99
OSE Stuffing tube clamp with oil fitting
1 of 2
Product ID ose-83037
Price$4.99
OSE Stuffing tube mount with oil fitting
1 of 3
Product ID ose-83010
Price$14.95
OSE Carbon Stuffing Tube Mount
1 of 2
Product ID ose-83029
Price$3.95
K&S Tubing Bender
Product ID ks-321
Price$4.57
Retaining Glue Loctite 603
Product ID mc-loc603
Price$21.99
Retaining Glue Loctite 638
Product ID mc-loc638
Price$24.99
Speedmaster Bushing 3/16" for Sport 20 & 21 Style Strut
Product ID ros-spds-014-bsf
Price$5.95
Speedmaster Bushing 1/4" for Large Struts
Product ID ros-spds-015-bsf
Price$5.95
