Leopard 2860 Motor
Product ID leo-2860
List Price: $55.70
Price: $44.95
Leopard 2860 brushless motor.
28mm Diameter by 64mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 85%.
Comes with high-quality bearings and neodymium magnets for high power.
Vent cutouts in the front and rear endbells allow air to circulate for additional cooling.
 We offer this in 7 versions.
Model Max Amps(A) Max Power KV(RPM/Volt)
LBP2860/6D38A1300W1690KV
LBP2860/5D47A1300W2040KV
LBP2860/2.5Y45A1300W2190KV
LBP2860/2Y60A1300W2730KV
LBP2860/3D80A1300W3400KV
LBP2860/2.5D85A1300W4050KV
Specs:
Magnets: neodymium
Watts: 600 with up to 1200 burst.
Poles: 4
Motor Shaft Diameter: 4mm with flat spot
Can Measures: 28mm diameter x 64mm long
Weight: 176 Grams
Mounting screw diameter required: 3mm threads.
Bearing size: 4mm wide x 10mm od x 4mm id.
Mounting Holes: 2 mounting patterns for ease of installation. Both 16mm & 19mm apart. Works with all the 380 Motor mounts we sell.
Includes Leopard 3.5mm male bullet plugs soldered to the motor and a matching set for your ESC connection
OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for sports boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not know how to pick the correct motor, please consult us first or other members of the RC Fast electric boating community. Either at a local club or on our OSE Forums.
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
Etti Adjustable Motor Mount 380-480 Size
1 of 2
Product ID etti-h009
Price$19.99
Etti Water Cooled 380 Size Motor Mount
1 of 2
Product ID etti-h011
Price$19.99
Adjustable Water Cooled Mount for 28mm Motors
1 of 2
Product ID ose-80100
Price$11.95
Adjustable Motor Mount for 28/36mm Motors
1 of 3
Product ID ose-80080-c
Price$10.95
Octura Coupler Flex Hex 4mm to .130 Cable
Product ID oct-ocfhe4mm13
Price$14.99
Octura Coupler Flex Hex 4mm to .150 Cable
Product ID oct-ocfhe4mm15
Price$14.99
Leopard 2830 Motor Water Jacket
Product ID leo-2830-jacket
Price$7.99
Leopard 2840 Motor Water Jacket
Product ID leo-2840-jacket
Price$8.99
OSE Aluminum coupler: 4mm Motor
Product ID ose-1345
Price$5.99
