Leopard 3660 brushless motor. 36mm Diameter by 60mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 90%. Comes with high quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance. 2050Kv 2.5Y 5mm Motor Shaft 2550Kv 2Y Specs: Magnets: neodymium Watts: 800 with upto 1300 burst. Poles: 4 Motor Shaft: 5mm Can Measures: 36mm diameter x 60mm long Weight: 251 Grams Mounting Screw diameter required: 3mm Bearing size: 5mm wide x 16mm od x 5mm id Flat Spot on shaft for tightening coupler screw to. Mounting Holes 25mm apart for use with most 540 mounts. Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your esc connection. Front and Rear vented end caps for additional cooling. OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums. Works with OSE-80230-b Water Cooled Motor Mount.
Pick up where you left off.
