RSX380 FE: Wood Outrigger Kit with Fiberglass Cowl (38" 965mm)
Product ID ml-rsx380
In Stock 0
Price: $239.99
The ML Boatworks RSX380 38" FE Outrigger Hydroplane Wood Kit. This is a kit that will require full assembly from the laser cut parts.
1st, 2nd & 3rd pictures show a completed rigger with optional hardware parts. This kit only includes the wood structure and white fiberglass Cowl (requires trimming).
ML Boatworks has toyed with the idea of introducing an outrigger into their stable for many years...well, the design, build, and testing is now completed, and we really like what we saw out on the water! This boat should be extremely competitive in the Q FE Outrigger Hydroplane classes (6s Lipo) as it can handle not only high end speeds will stability, on a rail type cornering, but it can also get you through the rough water we typically see on the race course.
1. Build thread on OSE Forum. Must be a registered member to view these.
2. Build thread on OSE Forum. Must be a registered member to view these.
Instructions are downloadable by clicking here
Specs:
Length: 38"
Hardware Recommended, See bottom of this page for links to items:
-Speedmaster Rudder ros-spdr-013
-Large Speedmaster round bottom/hydro Strut
-40 size Turn Fin
-K&S 8131 1/4" stuffing tube if you are using .187 cable
-OSE-187L Flex Cable
-Zippkits 5/16" Solid Carbon Boom Tube Rods or equivalent pn# zip-5603
-Zippkits Long Boom Tube Sleeves- 5/16" pn# zip-3586
-Zippkits Boom Tube Collars- 5/16" pn# zip-3480.
-KS Tubing 11/32 for the carbon booms to go through the tub.
Suggested power:
Motor: Leopard 4092 1480Kv with ZTW 200 ESC
or
Motor: Leopard 4092 1730Kv with ZTW 300 ESC
Battery: (1) 6s 65c 5000mah Lipo pack
NOTE: If you use larger than the suggested power, we suggest going to a larger 1/4" cable, 1/4" Strut and Larger stuffing tube.
To view the ML Boatworks RSX SERIES Build Manuals, please click the following link:
https://drive.google.com/open?id=1HeqWdr43cr3nqcnQ_sbB6qy7iXKN6UfH
Speedmaster Large 3/16" (.187) Strut
Product ID ros-spds-007
Price$29.95
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Leopard 4092 Motor
1 of 2
Product ID leo-4092
Price$94.95
Speedmaster 1" Rudder Assembly
1 of 2
Product ID ros-spdr-013
Price$44.95
5/16 Boom Tube Collars / Clamps (4 per pack)
Product ID zip-3480
Price$7.95
Long Boom Tube Sleeves- 5/16  (4 per pack)
Product ID zip-3586
Price$13.95
Solid Carbon Boom Rods 5/16 Inch
Product ID zip-5603
Price$15.99
