Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price: $4.49
Teflon liner, 24" (600mm approx) in length.
Flex Cable Size
Required Teflon Size
.062  (1.5mm)
Part # oc098t-24
.078  (2.0mm) Part # oc098t-24
.098" (2.50mm)  Part # oc098t-24
.130" (3.30mm)  Part # oc130t-24
.150" (3.81mm)  Part # oc150t-24
3/16" (4.75mm, .187" )  Part # oc187t-24
1/4" ( 6.37mm, .250" )  Part # oc250t-24
Note: Above are guideline for fit.
Teflon is not a high tolerance item and may need to be sanded or stretched to fit the stuffing tube.
Stuffing tube is not included.
2 Product Reviews - Average rating 5 / 5 (Show All)
Perfect Fit for Zonda
CURTIS BOYT - 30th January 2025
Liner fits 3/16 cables with no stretching or modifications. If you are doing the flex cable conversion on the Zonda be sure to replace liner and make it an inch longer. Although make your own measurements, factory liners may not be the right length to begread more
3.81 works with 4mm shafts
Mac - 04th September 2020
Works great, high quality.
High performance Sevan Outboard
1 of 5
Product ID bel-flex-2042
Price$169.99
Speedmaster Stinger Strut
1 of 7
Product ID ros-stinger-str
Price$59.99
TFL Aluminum Remote Controllable 1/4 Stinger Strut
1 of 3
Product ID tfl-503B92
Price$69.95
OSE .187 (3/16") reversed (right) cable with 3/16" prop shaft 3.25" long
Product ID ose-cable-1190-rev
Price$27.99
OSE .187 (3/16") cable : drive dog : bullet nut : 3/16" prop shaft : 3.25" long
Product ID ose-cable-187-XL
Price$39.99
Octura .187 cable, 24" long : Black
Product ID oct-oc187L-24a
Price$5.99
OSE .187 (3/16") cable with 3/16" prop shaft 3.25 long
Price$27.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
OSE 1/4" cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290
Price$34.99
OSE 1/4" reversed (right) cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290-rev
Price$34.99
OSE 1/4" cable with 1/4" prop shaft x 30" (760mm) Long
Product ID ose-cable-1295
Price$32.99
OSE 1/4" reversed (right) cable with 1/4" prop shaft x 30" (760mm) Long
Product ID ose-cable-1295-rev
Price$32.99
Octura .187 cable, 24" long - Reverse wind
Product ID oct-oc187R-24a
Price$4.29
2mm wire drive with 4mm shaft
Product ID tfl-510B02
Price$7.99
2mm wire drive with 4mm threaded end
1 of 2
Product ID tfl-510B03
Price$7.95
Teflon Liner 20 Foot bulk package (600cm)
Product ID oct-teflon-240
Price$39.99
4mm Shaft with 4mm flex cable
Product ID tfl-510b24
Price$14.99
Octura 3/16" stepped down to 1/8" prop shaft for .150 flex cable
Product ID oct-oc61504ps
Price$4.99
Octura 3/16" prop shaft for .130 flex cable
Product ID oct-oc6130ps
Price$4.99
Octura 3/16" prop shaft : 2.25" : for .150 flex cable
Product ID oct-oc6150ps
Price$5.49
Octura 3/16" Long prop shaft : 3" : for .150 flex cable
Product ID oct-oc6150psL
Price$4.99
Octura 3/16 to 1/8" prop shaft for .062 Piano wire & 1/8" props
Product ID oct-oc60624ps
Price$5.49
Octura 3/16" Prop shaft for .062 piano wire: 2.25" Long
Product ID oct-oc6062ps
Price$5.49
Octura 3/16" Prop shaft for .062 piano wire: 3.00" Long
Product ID oct-oc6062ps-L
Price$5.49
