Linkage Rod Connector for 4-40 Rod
Product ID ose-83106
In Stock 57
Price: $2.49
Linkage Rod Connector for 4-40 rod.
 See picture 2 for measurements.
For 4-40 push rods. Will accept linkage rods. The linkage connection is secured with 4-40 hex screw and held to the rudder with a 4-40 stainless & nylon insert lock nut. The body of the connector is made of stainless steel.
Specs:
(1) Stainless Connector per pack
(1) 4-40 thread x 3/16" long hex screw for holding rod in place. pn# mc-92196A105
(1) 4-40 threaded nylon insert lock nut. pn# mc-91831A005
Dual Arm Control Horn for Large Speedmaster Rudders 40/60
Product ID ros-spdr-018-da
Price$15.99
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
Du-Bro 518 4-40 Pull-Pull System
Product ID hh-518
Price$12.99
Scale Outboard with Metal Lower Unit: All Black
1 of 3
Product ID bel-2041-alu
Price$199.99
Prather 4-40 Radio Box Seals
Product ID hpi-pra8112
Price$9.99
Speedmaster 40 Rudder Assembly
1 of 2
Product ID ros-spdr-010
Price$39.95
Speedmaster 1" Rudder Assembly
1 of 2
Product ID ros-spdr-013
Price$46.99
Speedmaster Dual Pickup Tapered Rudder Assembly
Product ID ros-spdr-011a
Price$49.99
Speedmaster Dual Pickup Straight Blade Rudder Assembly
1 of 4
Product ID ros-spdr-012
Price$49.99
Speedmaster Center Mount Dual Pickup Tapered Blade
1 of 3
Product ID ros-spdr-011a-60sb-tee
Price$49.99
Speedmaster Center Mount Dual Pickup Straight Blade
1 of 3
Product ID ros-spdr-012-dusb-tee
Price$49.99
Du-Bro Swivel Ball Link for 4-40 Pushrod & 2-56 screw
Product ID hh-369
Price$3.19
Du-Bro Swivel Ball Link for 4-40 Pushrod & 4-40 screw
Product ID hh-497
Price$2.79
Du-Bro Swivel Ball Link for 4-40 pushrod (2 Pack)
Product ID hh-2161
Price$5.99
Recently Viewed
Pick up where you left off.
