OSE XL Quick Change Motor Mount for Ten Shock 22 series motors
Product ID ose-83357
In Stock 0
List Price: $39.99
Price: $34.99
40mm Quick Change Mount, designed by Anthony Vaccaro.
Designed to speed up swamping of a motor during a race or if your just tired of trying to remove the front screws on your motor for maintenance.
Once the coupler is loosened, the motor can be removed in less than a minute. Normally racers would have to remove the front screws which could take a few minutes and more importantly, once a motor is removed in a conventional mount, the motor angle has to be realigned. With only 4 screws the motor is removed, while maintaining the motor angle. Also features clear access to the front motor vents to allow maximum cooling. See video for a quick change.
Material:
Carbon fiber stands
Aluminum cnc motor brackets.
Measures:
62mm wide (not including protruding screws)
140mm long
See picture 6 for carbon stand bracket size.
Motor applications:
Ten Shock 2250, 2260, 2270 and 2280 Motors with 6 Bolt front motor plates.
Requires you to provide motor mounting screws. m3 x 6mm long screws
 Includes: Mount in picture 2. NO motor included
Tenshock Evo 2250 "High Power" Version (40mm x 79.5mm long)
1 of 3
Product ID ten-evo-2250-HP
Price$259.99
Tenshock Evo 2260 "High Power" Version (40mm x 90.0mm long) :
1 of 3
Product ID ten-evo-2260-HP
Price$279.99
Tenshock Evo 2270 "High Power" Version (40mm x 99.5mm long) :
1 of 4
Product ID ten-evo-2270-HP
Price$319.99
Tenshock Evo 2280 "High Power" Version (40mm x 109.5mm long) :
1 of 4
Product ID ten-evo-2280-HP
Price$359.99
Tenshock Evo 2290 "High Power" Version (40mm x 119.5mm long) :
1 of 4
Product ID ten-evo-2290-HP
Price$379.99
M3 Hex Head Screw : Stainless
Product ID mc-91292-m3
Price$0.20
