Search products
Search
Cart (
0
Close
Shop Now
Motors
ESCs
Batteries
Propellers
Hulls & Kits
Radios
Tools
New Items
Shop by Brand
View All Categories
Videos
Tips & Info
Links
Speed Calculator
New Items
OSE Rewards
Shop Now
Shop by Manufacturer
Videos
Tips & Info
Links
Speed Calculator
New Items
OSE Rewards
My Account
Cart (0)
Your Name
Your Email
Your Friends Email
Your Comments
Send
Close Window
Login Details
Email
Password
Submit
New Account
Forgot Password?
New Account
Full Name
Email
Password
Allow Promotional Emails
Create Account
Motors
Brushless Motors
Checkout
Tenshock Evo 2280 "High Power" Version (40mm x 109.5mm long) :
Product ID
ten-evo-2280-HP
List Price:
$389.99
Price:
$359.99
Winds/Rpm
Please Select...
700Kv 6Y
850Kv 5Y
1050Kv 4Y
1400Kv 3Y
2050Kv 2Y
Add to cart
Ask a Question
Tell a Friend
Evo TS-MI-EVO2280-HP High-Power version: 40x109.5mm: 6 Pole Motor.
-See picture 2 for motor chart
Powerful 6-pole core design for high torque output.
Advanced assembly technology enables more efficient use of space.
CNC-machined aluminum casing
Silver-copper wire alloy for super-high efficiency compared to basic copper alloy wire.
Powerful sintered neodymium magnets
High torque-to-weight ratio.
The hand-wound weaving of the winding ensures the motor has excellent electrical characteristics!
Includes a free water jacket with an internal water channel to ensure water flows around the motor
High-grade bearings
Specs:
Magnets: neodymium
Watts: 9,500
Poles: 6
Motor Shaft: 8mm
Shaft Length: 21.5mm
Can Measures: 40mm diameter x 109.5mm long
Weight: 650 Grams
Mounting Screw diameter required: 4mm
Bearing size: (front), (rear)
Connectors: OSE suggests 8mm
Water jacket length: 80mm
OSE suggests 30,000-40,000 total rpm. These are only guidelines; if you don't know how to choose the correct motor, please consult OSE first or other members of the RC Fast electric boating community, either at a local club or on our OSE Forums.
* It is important to note that the "Max Amps" value represents the maximum recommended operating current for the motor. It does not indicate the maximum current the motor can draw. For instance, the 1400kv motor has a "Max Amp" rating of 210. This means the motor should not be operated at a current exceeding 210 amps. However, this does not imply that a 200 amp ESC will be compatible with the motor. Instead, the user must select a propeller or gearing that prevents the motor from exceeding its "Max Amp" rating. It is important to note that the 210-amp motor can and will exceed the 210-amp rating when pushed beyond its limits for a short period.
Click to review this product
« Previous
Next »
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
Safe & secure payments
Talk to real RC boaters
PREV
of 3
NEXT
Fully adjustable 40mm diameter motor mount with carbon stands.
Product ID
tfl-523b63
Price
$29.99
Configure
PREV
of 2
NEXT
OSE 8.0mm Bullet Connectors
Product ID
ose-8mm-bullet-v2
Price
$2.29
Notify when back in stock
PREV
of 3
NEXT
Castle Creations HYDRA Cobra 5, 8S, 33.6V ESC, 20A PEAK BEC : Free Shipping on this Item
Product ID
cas-010-0182-00
Price
$349.99
PREV
of 6
NEXT
OSE XL Quick Change Motor Mount for Ten Shock 22 series motors
Product ID
ose-83357
Price
$34.99
PREV
of 5
NEXT
OSE Quick Change 5" Rail Motor Mount for TenShock 40mm Motors
Product ID
ose-83415-ten
Price
$44.99
Add to cart
Octura Coupler Flex Hex 8mm to .187
Product ID
oct-ocfhe8mm18
Price
$22.99
Add to cart
Octura Coupler Flex Hex 8mm to .250
Product ID
oct-ocfhe8mm25
Price
$22.99
Add to cart
TFL Collet Style Coupler: 8mm - .187 (3/16" : 4.75mm)
Product ID
tfl-529b85
Price
$14.99
Add to cart
PREV
of 2
NEXT
TFL Collet Style Coupler: 8mm - .250 (1/4" : 6.35mm)
Product ID
tfl-529b87
Price
$14.99
Add to cart
Have OSE solder the connectors to a Motor
Product ID
ose-custom-solder-motor
Price
$24.99
Configure
