OSE Propeller Adapter
Product ID ose-83400
Price: $1.99
This product is used to fit different propellers onto different sized shafts. For example, if you have a 4mm propeller shaft, but want to have access to the hundreds of 3/16" (.187", 4.75mm) propellers on the market, this item is for you. This slides over your existing 4mm prop shaft to act as a shim to adapt 3/16" (.187) props.
Available in 4 Size Options
- 1/8" to 3/16" pn# ose-83400-18316: Comes in an anodized Metallic Red color
- 4mm to 3/16" pn# ose-83400-4316: Comes in an anodized Metallic Blue color
- 3/16" to 1/4" pn# ose-83400-31614: Comes in Metallic silver color
- 5mm to 1/4" pn# ose-83400-514: Comes in a Metallic yellow color
Includes
(1) Sleeve Per Package
Specs
- ose-83400-18316: Allows a propeller with a 3/16" hub to fit onto a 1/8" shaft
- ose-83400-4316: Allows a propeller with a 3/16" hub to fit onto a 4mm shaft
- ose-83400-31614: Allows a propeller with a 1/4" hub to fit onto a 3/16" shaft
- ose-83400-514: Allows a propeller with a 1/4" hub to fit onto a 5mm shaft
« Previous | Next »
TFL lower unit parts for the TFL scale outboard pn# tfl-b54210
1 of 2
Product ID tfl-b54210-H
Price$79.99
Straight shaft with brass stuffing tube.
1 of 3
Product ID tfl-515b-xx
Price$13.99
OSE 1/4" cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290
Price$34.99
OSE 1/4" reversed (right) cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290-rev
Price$34.99
TFL P1 Drive System with 2960 Motor
1 of 6
Product ID tfl-b42515
Price$219.99
TFL Scale Outboard with sss 3660 brushless motor
1 of 7
Product ID tfl-B54210
Price$189.99
Etti 4mm to 3/16"(4.75mm) prop adapter
Product ID etti-a126
Price$5.99
ROV Adapter 1/8 Motor to 4mm or 3/16" propeller
1 of 2
Product ID ose-83397
Price$11.95
