TFL Scale Outboard with sss 3660 brushless motor
Product ID tfl-B54210
In Stock 16
List Price: $249.99
Price: $189.99
TFL Scale Outboard with Black Cover (No Graphics Applied)
This is the outboard system only. Picture 4 shows this system installed in a TFL Warrior P1 Superstock hull. Picture 5 shows the diagram and parts list.
Motor Specs:
 Motor:
TFL SSS 3660 2075 v2 Brushless Motor with 4mm male connectors.
- Diameter: 36mm
- Connectors: 4mm Female Bullet Connectors
- Length: 60mm
- Shaft diameter: 5mm Shaft
- Includes water jacket.
Outboard Specs:
- 185mm from the bottom of the skeg to the top of the outboard cover.
- The cover is 55mm wide
- 550 Grams (approx.) with a brushless motor.
- 280 Grams (approx.) without a brushless motor.
- Drive Shaft: 4mm Propeller shaft, requires drive dog-style propellers.
- Fits up to 48mm Prop
- Gear-driven lower unit.
Requires:
- Everything besides the outboard unit.
- Suggested ESC: Raider 150 ESC or Seaking 160 ESC. Both will require you to solder the correct 6mm connectors to the motor.
- 2s or 3s maximum, 40c 4000 to 5000mah lipo pack.
- Propeller for 4mm prop shaft; the diameter of the prop will depend on the application.
- M3 x 6mm or longer (depending on application)
Notes:
-IMPORTANT: See picture 6 for the screw that needs to be removed to pull out the prop bushing and propeller shaft.
-Recommended for 30"(750mm) to 40" (1000mm) hull. The bare hull should be up to 2 pounds.
-We recommend no larger than a 36mm diameter x 60mm long motor and a total rpm of 23k or Less. Any higher Kv/larger motor could damage the gear system or other parts.
-These are gear-driven and can be used with a left or right-rotation propellers.
-Standoff bracket tfl-B54210-14 may be required, depending on the application.
Maintenance Video.
7 Product Reviews - Average rating 4.9 / 5 (Show All)
TFL updated outboard unit
Steven Fileccia - 24th February 2025
I just received my 5th outboard unit. This is the newly updated for 2024.
Please note: strongly recommend to take apart and add blue lock tite to all the metal to metal screws and set screws. It is very easy to do.
These newer units have better lower uread more
Amazing motor
Desmond charles - 16th July 2024
Ordered to be shipped to the usvi and it came extremely fast it was ordered on Thursday and it came Monday it looks identical to the real mercury and is made with high quality...can't wait for more to be in stock to get another one I'm building a twin engread more
amazing product
G man - 13th July 2023
When it arrived and opens the package I loved it and could you send me another one please
Put it on a 29” black jack !!
Jay - 14th May 2021
Works great, after jus time run though had to replace the bearing in the lower unit in the prop shaft! But very pleased with it !
TFL outboards best bang for the buck
Steven F. - 07th May 2019
I currently have just about every type of electric outboard motor on the market, and I can say the TFL Scale outboard is one of the best. I now own 5 of these and the machining is fantastic, Performance is fantastic, and maintenance is WAY easier than theread more
scale looks with plety of power
scale racer - 14th November 2018
I put this on a 28" scale run about I built. Its crazy fast for this boat and looks terrific. For the money, its one of the best on the market.
Fiberglass X-Cat : Bare Hull (31.25" 794mm)
1 of 7
Product ID kva-2280gr
Price$259.99
OSE Propeller Adapter
1 of 5
Product ID ose-83400
Price$1.99
TFL scale outboard part: Replacement blade mount
Product ID tfl-b54210-05
Price$7.95
TFL scale outboard part: Replacement Lower Housing
1 of 2
Product ID tfl-b54210-09
Price$44.99
TFL scale outboard part: Replacement Connector A
Product ID tfl-b54210-16
Price$2.99
TFL scale outboard part: Replacement Connector B
Product ID tfl-b54210-17
Price$3.99
TFL scale outboard part: Replacement Connector C
Product ID tfl-b54210-18
Price$1.49
TFL lower unit parts for the TFL scale outboard pn# tfl-b54210
1 of 2
Product ID tfl-b54210-H
Price$79.99
2-56 Linkage Rod (1.8mm diameter)
1 of 2
Product ID hh-2-56-3751
Price$1.49
Power HD 20Kg : Standard size : Waterproof : Metal gear : Digital servo
1 of 3
Product ID pow-lw-20mg
Price$24.99
Power HD 25Kg : Standard size : Waterproof : Metal gear : Digital servo
1 of 3
Product ID pow-lw-25mg
Price$39.99
Bearing 4mm x 8mm x 3mm
1 of 2
Product ID tfl-4x8x3
Price$2.99
Bearing 4mm x 7mm x 2.5mm : (2/Pack)
1 of 2
Product ID tfl-557b35
Price$3.99
OSE Raider 150 Esc with Ec5 connectors : Free Shipping
1 of 2
Product ID ose-R-150C-Ec5
Price$69.99
OSE Raider 150 Esc with Qs6 connectors : Free Shipping
1 of 5
Product ID ose-R-150C-Qs6
Price$69.99
Power HD 30Kg : Standard size : Waterproof : Metal gear : Digital servo
1 of 3
Product ID pow-lw-30mg
Price$29.99
Power HD 30Kg : Standard size : Waterproof : Titanium gear : Digital servo
1 of 3
Product ID pow-wh-30kg
Price$56.99
P1 Drive Part : 10T Tapered Straight Gear A
Product ID tfl-b42515-04
Price$11.99
P1 Drive Part : 10T Tapered Straight Gear B
Product ID tfl-b42515-06
Price$12.95
P1 Drive Part : Stern Bearing Bracket
1 of 3
Product ID tfl-b42515-11-v2
Price$6.95
P1 Drive Part : Stern Bearing Bracket with bearings and thrust bearing
1 of 2
Product ID tfl-b54210-e
Price$14.99
P1 Drive Part : Drive Dog for P1 & Scale TFL Outboard
Product ID tfl-b42515-16
Price$2.95
P1 Drive Part : Spacer / Shim
Product ID tfl-b42515-36
Price$1.00
SSS 3660 V2 Brushless Motor
Product ID tfl-sss-3660-v2
Price$54.99
TFL Caudwell F1 with Scale Outboard (tfl-B54210)
1 of 6
Product ID tfl-1238T-F
Price$799.99
TFL 4mm Thrust Washer : 10 x 4 x 1
Product ID tfl-b42515-18
Price$0.69
TFL P1 Superstock Warrior -Red & Black paint scheme
1 of 6
Product ID tfl-1148-Red
Price$649.99
Replacement Scale Outboard Cover ONLY: Black Gloss
1 of 4
Product ID tfl-b54210-08
Price$19.95
Adjustable Standoff mounting bracket for TFL Scale Outboard (pn# tfl-B54210)
1 of 4
Product ID tfl-B54205
Price$39.99
V2 Steering Mount for TFL Scale Outboard (pn#tfl-B54210)
1 of 2
Product ID tfl-B54210-12-v2
Price$9.99
V2 Transom Hinge bracket for TFL Scale Outboard
1 of 3
Product ID tfl-B54210-13-v2
Price$14.99
