OSE Raider 150 Esc with Ec5 connectors : Free Shipping
Discounts Apply !
Free Shipping on Select Items
Product ID ose-R-150C-Ec5
In Stock 22
List Price: $79.99
Price: $69.99
OSE Raider 6s 150 Amp ESC with EC5 connectors preinstalled for ease of installation. Designed with a large heat sink and dual water cooling tubes for superior cooling. Heavy 10-gauge wire and 4 capacitors.
We custom-make the OSE Raider 150 ESCs using a Fly Color 150 as our base unit, then install the following to improve performance.
- Extra capacitor bank for improved performance.
- Longer motor wires
- Preinstalled EC5 connectors on the motor and battery ends.
- And most importantly, the after-sales service from OSE within the USA. Instead of having to return things to China.
We made this super easy to install
for stock setups; we have installed a Blue EC5 connector on the battery side with OSE 6mm female bullet connectors on the motor side. See picture 1
This allows a plug-and-play ESC when combined with many of the rtr's on the market, and the Leopard Motors we sell (contact us if in doubt about your setup).
This ESC is specially designed for use in RC boats.
- Excellent waterproof design allows this ESC to work in wet conditions.
- Optional LED Program Box for easy setting of all the ESC's parameters.
- Low voltage protection.
- Thermal protection, if the ESC goes over 100C (212F) the output will reduce to and not return to normal until the temperature reaches 80c (176F) or less.
- Built-in BEC (battery eliminator circuit) to power your receiver.
- Throttle signal loss protection.
- Programmable for Forward with Reverse or Forward only.
Specification:
- Continuous Current: 150 Amps
- Peak Current: 900 Amps. This is only for a brief second or so.
- Wire size: 10 Gauge
- Input: 2-6S (7.4volts - 22.2volts) Lipo
- BEC Type: Switch Model
- BEC Output: 5.5V/5A
- Weight: 215 Grams
- Size (excludes the Water Cooling Pipe): 76mm X 56mm X 25mm
- Connector: Battery side, EC5
- Connector: Motor side: Female 6mm OSE
- Water cooling fittings: 5mm threads.
Click here for full esc manual.
Click here for program box manual.
Includes everything in picture 1
(1) OSE Raider 150 Esc
(3) Installed ose-6bullet connectors soldered onto the ESC motor end.
(1) Installed EC5 Male connector soldered onto the ESC battery end.
Note: This ESC was designed to work in an environment where it's possible for the ESC to get wet on occasion. Not for use underwater. OSE does not suggest using this item underwater! This ESC is suggested for smaller boats up to the 28"- 40" (700mm - 1000mm) range. Because there are so many variables with each hull and installation, it's impossible to specify all the applications for this ESC. If you have any questions about using this ESC with your particular boat, please contact us before purchasing.
6 Product Reviews - Average rating 4.3 / 5 (Show All)
This esc is no joke.
Patrick - 16th September 2024
I ran a setup on this esc that datalogged a peak of 409amps with an xlx2. And the raider 150 servived the run.
I would say in my opinion 150 amps continious is about right for longer runtimes. And from experience you can propably use it for saw runs. Iread more
best bang for the buck
Maier - 05th August 2024
I bought this because it plugged right into most of the motors I use in my rtr boats. OSE recommended a 40mm motor for my traxxas spartan and now its faster and runs longer.
used in my Sonic wake, worked great
Pat - 02nd August 2024
changed the motor connectors and used this with 6s in my sonic wake. 70mph on 6s
Blew up 3rd run
Carson - 17th July 2024
I didn’t even use one full battery on this esc and the battery to the esc blew up ruined the foam to the Traxxas M41
Best bang for your buck! Handles 150 continuous all day!
Matthewa64 - 16th February 2024
I have purchased four ESC’s and the easy-to-use program card is a must have! Very versatile and robust with eight timing settings 0-26.25, a 900 amp peak, waterproof, not just water resistant, and 10 gauge wires on both battery and motor sides, this bread more
Best ESC for the money handles the amps.
Vinny - 30th December 2023
EC5 connectors.
6mm bullet connectors for motor.
Makes it Plug n play for most boats.
Extra capacitors.
Love that it's a lot thinner then the T180 ESC alot wider but thinner and way cheaper.
« Previous | Next »
TFL Outboard lower unit - Nitro or Electric ready!
1 of 6
Product ID tfl-542b40
Price$159.99
OSE 8mm od x 4mm id tubing : 3' (900mm) long
1 of 13
Product ID mo-color-tub-8mm
Price$6.99
OSE Large 1/4" Silicone Tubing
Product ID ose-tubing_1-4_clear
Price$3.99
OSE EC5 Parallel Harness
Product ID ose-ec5-parallel
Price$9.99
OSE EC5 Series Y Harness
Product ID ose-ec5-series
Price$10.99
OSE 6.0mm Bullet Connectors
Product ID ose-6mm-bullet
Price$1.65
Programming Card for OSE Raider Esc's
1 of 2
Product ID ose-R-box
Price$9.99
Charge Lead for EC5 Connectors
Product ID ose-ec5-chrg
Price$6.95
SSS 3656 Brushless Motor : 6 Pole
1 of 3
Product ID tfl-sss-3656
Price$69.99
Delta Force 26: Bare Hull (25.5" 648mm)
1 of 4
Product ID df-delta-26
Price$139.99
TFL Scale Outboard with sss 3660 brushless motor
1 of 7
Product ID tfl-B54210
Price$189.99
EC5 Male Connector by E-flite
Product ID hh-eflaec501
Price$7.99
EC5 Female Connector by E-flite
Product ID hh-eflaec502
Price$7.99
EC5 Connector
1 of 3
Product ID ose-ec5
Price$1.50
OSE Raider 6s Capacitor Pack
Product ID ose-R-cap
Price$6.99
Labor to solder connectors onto purchased ESC
Product ID ose-custom-solder-esc
Price$0.01
