OSE Raider 150 Esc with Qs6 connectors : Free Shipping
Discounts Apply !
Free Shipping on Select Items
Product ID ose-R-150C-Qs6
In Stock 83
List Price: $79.99
Price: $69.99
OSE Raider 6s 150 Amp ESC with Qs6 connectors preinstalled for ease of installation. Designed with a large heat sink and dual water cooling tubes for superior cooling. Heavy 10-gauge wire and 4 capacitors.
We custom-make the OSE Raider 150 ESCs using a Fly Color 150 as our base unit, then install the following to improve performance.
- Extra capacitor bank for improved performance.
- Longer motor wires
- Preinstalled Qs6 6.00mm Bullet connectors on the battery side and OSE 6.00mm bullet connectors on the motor side.
- And most importantly, the after-sales service from OSE within the USA. Instead of having to return things to China.
We made this super easy to install for stock setups; we have installed an OSE Qs6 connector on the battery side with OSE 6mm bullet connectors on the motor side. See picture 1. This allows a plug-and-play ESC when combined with the Leopard Motors we sell (contact us if in doubt about your setup), while allowing more amp draw due to the larger OSE Qs6 connectors we use.
We made this super easy to install with 2 connector options.
 - For modified setups, OSE-qs6p high-amp connector on the battery side with 6mm female bullet connectors on the motor side. See picture 2
Using OSE 6mm bullet connectors on the motor side allows a plug-and-play ESC when combined with the Leopard Motors we sell (contact us if in doubt about your setup).
This ESC is specially designed for use in RC boats.
- Excellent waterproof design allows this ESC to work in wet conditions.
- Optional LED Program Box for easy setting of all the ESC's parameters.
- Low voltage protection.
- Thermal protection, if the ESC goes over 100C (212F) the output will reduce to and not return to normal until the temperature reaches 80c (176F) or less.
- Built-in BEC (battery eliminator circuit) to power your receiver.
- Throttle signal loss protection.
- Programmable for Forward with Reverse or Forward only.
Specification:
- Continuous Current: 150 Amps
- Peak Current: 900 Amps. This is only for a brief second or so.
- Wire size: 10 Gauge
- Input: 2-6S (7.4volts - 22.2volts) Lipo
- BEC Type: Switch Model
- BEC Output: 5.5V/5A
- Water cooling fittings: 5mm threads.
- Weight: 215 Grams
- Size (excludes the Water Cooling Pipe): 76mm X 56mm X 25mm
- Connector: Battery side, Qs6
- Connector: Motor side: Female 6mm OSE
Click here for full esc manual.
Click here for program box manual.
Includes:
(1) OSE Raider 150 Esc
(3) Installed ose-6bullet connectors soldered onto the ESC motor end.
(1) Installed ose-qs6p on the ESC battery end.
Requires:
Customers must have OSE QS6 high-amp connectors installed on their ESC.
Note: This ESC was designed to work in an environment where it's possible for the ESC to get wet on occasion. Not for use underwater. OSE does not suggest using this item underwater! This ESC is suggested for smaller boats up to the 28"- 40" (700mm - 1000mm) range. Because there are so many variables with each hull and installation, it's impossible to specify all the applications for this ESC. If you have any questions about using this ESC with your particular boat, please contact us before purchasing.
7 Product Reviews - Average rating 5 / 5 (Show All)
One of the best ESC
Koen Schenk - 13th September 2023
I run this esc in cats one with a lehner 1950 and one with aTP4060 and they perform so good they can handle serious amps
Great esc for the money
Dylan Albert - 06th April 2022
I use this in my ul19 and it perfect. Its my go to esc
Cant beat it for the money
Jerry - 23rd November 2020
This is similar to the ebay model but with some extras I like. Longer wires and it already has the caps built in. Plus the one I bought from China took 5 weeks to get. this one I had in 2 days.
perfect esc
vitto - 16th August 2019
Ive used this in my 4s p limited setup for close to 2 years now. No problems.
great company and esc
Matt - 12th February 2018
great esc and service from Offshore Electrics!
I bought one of these at another company and had an issue setting it up. The company would not return my emails. After finding them for sale here, I emailed and Steven returned my email to help with the siread more
Raider 150A ESC
beaux - 26th October 2017
This is a very good unit .
Have had zero problems.
Great buy.
OSE Leopard 4082 Motor & Raider ESC Package
Product ID ose-4082-R-Combo
Price$169.99
SSS 3682 with Raider 150 ESC Combo
1 of 2
Product ID ose-sss-3682-combo
Price$149.99
OSE 8mm od x 4mm id tubing : 3' (900mm) long
1 of 13
Product ID mo-color-tub-8mm
Price$6.99
OSE Large 1/4" Silicone Tubing
Product ID ose-tubing_1-4_clear
Price$3.99
OSE 6.0mm Parallel Harness for ose-qs6p connectors
Product ID ose-qs6-parallel
Price$9.99
OSE 6.0mm Series Y Harness for ose-qs6p connectors
Product ID ose-qs6-series
Price$9.99
OSE Qs6 Connector to EC5 Series Harness
Product ID ose-qs6-series-ec5
Price$9.99
OSE Qs6 Connector to EC8 Sereis Harness
Product ID ose-qs6-series-ec8
Price$9.99
OSE 6.0mm Bullet Connectors
Product ID ose-6mm-bullet
Price$1.65
Programming Card for OSE Raider Esc's
1 of 2
Product ID ose-R-box
Price$9.99
OSE Charge Lead for OSE Qs6p Connectors
Product ID ose-qs6-chrg
Price$6.95
OSE 6.0mm male/female connector & Red housing
Price$1.85
TFL Scale Outboard with sss 3660 brushless motor
1 of 7
Product ID tfl-B54210
Price$189.99
Zipp Kits G30 Tunnel Hull Kit : Wood with Cowl (30.5" 775mm)
Product ID zip-g30-6516
Price$99.99
OSE Raider 6s Capacitor Pack
Product ID ose-R-cap
Price$6.99
Labor to solder connectors onto purchased ESC
Product ID ose-custom-solder-esc
Price$0.01
