OSE upgraded AquaCraft SuperVee 27 and 27R Cable
Product ID ose-cable-sv27
In Stock 4
Price: $39.99
OSE Flex Cable Assembly for the AquaCraft Super Vee 27, SuperVee 27R, and Super Vee Nitro boats.
Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is higher quality, with thicker wire strands and better alignment with the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
This can also be used in any other boat requiring a .150 cable that measures 12" from tip to tip.
No soldering or cutting is required!
Includes: Teflon Liner, cable with prop shaft and attached drive dog, and brass bullet nut.
How-To Guides Using This Part
The basics on flex cables
All how-to articles
