Power HD 30Kg : Standard size : Waterproof : Titanium gear : Digital servo
Product ID pow-wh-30kg
In Stock 10
List Price: $62.99
Price: $56.99
Power HD 30Kg : Standard size : Digital servo : Aluminum case with Titanium Gears.
Torque(6.0V): 22.0 kg-cm ( 305.5 oz/in)
Torque(7.4V): 26.0 kg-cm ( 361.1 oz/in)
Torque(8.4V): 30.0 kg-cm ( 416.6 oz/in)
Speed: 0.16 sec (6.0V)│0.13 sec (7.4V)│0.11 sec (8.4V)
Operating Voltage:6.0 ~ 8.4 DC Volts
Weight: 82 g (2.89 oz)
Bearing Type:Ball Bearing x 2
Motor Type:Coreless Motor
Gear Type:Titanium & Steel
Operating Temperature:-20℃~60℃
Working frequency:1520μs / 333hz
Size:40.7 x 20.5 x 38.5 mm ( 1.60 x 0.81 x 1.52 in)Servo Arm: 25T
Note: When the digital steering gear is subject to resistance will be issued a continuous creak current sound, the greater the resistance sound the more loud, this is a normal phenomenon. Not for use underwater.
1 Product Reviews - Average rating 5 / 5 (Show All)
Very good servo
Dan D - 18th August 2026
I picked up this servo for a mid size mono build, and it has 0 issues. It holds the rudder angle perfectly, it's almost completely silent, and it's well built and waterproof - all aluminum case. I'll be getting more of these in the future.
Power HD 20Kg : Standard size : Waterproof : Titanium gear : Digital servo
1 of 3
Product ID pow-wh-20kg
Price$52.99
Power HD 40Kg : Standard size : Waterproof : Titanium gear : Digital servo
1 of 3
Product ID pow-wh-40kg
Price$59.99
TFL Scale Outboard with sss 3660 brushless motor
1 of 7
Product ID tfl-B54210
Price$189.99
TFL Genesis 56 Catamaran 1420mm Carbon Fiber Stepped Hull Cat W/ Twin 5684 Motor 300A ESC
1 of 6
Product ID tfl-1132-C
Price$2,599.99
