CNC Cleaver 3 Blade : 1.6 Pitch : 42 to 50mm
Product ID cnc-xx16350
Price: $29.95
CNC 1.6 Pitch 3 Blade Cleaver Prop, Magnalium 7075 propeller.
The 50mm size comes in either Red or Silver.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
 CNC 1.6 Pitch 3-Blade Cleaver Propeller Size Chart
Part NumberDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-421635042 mm (1.65")67.22.653/16"
cnc-461635046 mm (1.81")73.62.903/16"
cnc-501635050 mm (1.97")80.03.153/16"
Specifications:
  • Pitch ratio: 1.6
  • Blades: 3
  • Material: Magnalium 7075 alloy
  • Mounting & Shaft Size: 3/16" (4.75mm) Drive dog.
  • Rotation: Counterclockwise when viewed from behind the boat. See picture 1 to view the prop's rotation.
    Note: 50mm for Proboat Blackjack 42
CNC Cleaver 3 Blade : 1.6 Pitch : Reversed Rotation : 42 to 50mm
1 of 3
Product ID cnc-xx16350-R
Price$29.95
