Medium Offset Catamaran Strut and Rudder System
Product ID tfl-502b35
In Stock 13
List Price: $79.99
Price: $59.99
Offset aluminum rudder and strut system for Catamarans with built-in water pickup. Features a nylon breakaway bolt on the rudder to reduce damage when hit by submerged objects.
The mounting plate measures 30mm (1.18") wide x 24mm (.95") tall.
The leading edge of the rudder blade measures 87mm (3.42")
Includes:
 - .187" (4.75mm) Flex Cable with 3/16" (4.75mm) shaft and 7mm Stuffing Tube
System includes the following hardware:
(1) aluminum rudder
(1) aluminum strut with an installed 3/16" Lead Teflon Bearing Sleeve.
(1) 3/16" flex cable with 7mm Stainless Stuffing tube with teflon.
Requires:
Requires the customer to cut the flex cable to the required length.
Du-Bro 489 or 490 steering linkage connectors.
489 is for 2-56 linkage rod, and 490 is a much stronger 4-40 linkage rod but will require drilling the the hole larger on the steering arm.
2 Product Reviews - Average rating 5 / 5 (Show All)
Awesome piece of hardware
WILLIAM FENTON - 15th April 2017
I've just purchased this for a cat project. I have looked around multiple places, and this seems to be a perfect fit for a HK Genesis cat. The hull has a very small mounting area for the strut.
Sweet Deal
Paul VanSchouwen - 19th November 2016
this is a really good deal , everything in one package including a brass bullet nut for $60 cant beat that.
fit an finish is very nice , im mounting it on a 30 inch shovel nose hydro.cant wait to see it run
Large Offset Catamaran Strut and Rudder System
1 of 4
Product ID tfl-502b36
Price$69.99
Delta Force 36 Explorer Catamaran Bare Hull (36.75" 934mm)
1 of 7
Product ID df-Cat-36
Price$249.99
Etti Coupler 5mm to .187" Cable
Product ID etti-a034
Price$12.99
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
Dual Pickup Rudder Blade for TFL Genesis 900, Zonda, Popeye, Apparition or ProMarine Skater
1 of 3
Product ID ose-83248
Price$19.99
