Speedmaster 40 Rudder Assembly
Product ID ros-spdr-010
Price: $39.95
This SpeedMaster rudder assembly is made for large nitro and electric hulls 33" (800mm) or larger. Comes with a built in water pickup. High quality aluminum, CNC cut to tight tolerances. The rudder features a break away brass screw in the rudder bracket to help minimize damage from the blade hitting a object while driving. Comes with basic mounting screws.
The rudder blade measures 6 1/4" long from top to bottom.
 The rudder blade is 1 3/4" wide at the top and tappers down to 5/8" wide at the bottom.
We offer this with 5 different brackets.
-Bracket with 1 1/8" of setback.
-Bracket with 1 5/8" of setback.
-Bracket with 2 1/4" of setback.
-Extended bracket with 4" of setback (pictured).
-XL bracket with 5" setback.
 Setback measurement is from the transom to the front of the rudder blade. We also sell just the rudder blade itself. This can be used as a repair replacement instead of buying the entire rudder assembly.
Dual Arm Control Horn for Large Speedmaster Rudders 40/60
Product ID ros-spdr-018-da
Price$15.99
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
Speedmaster rudder water fitting 10-32 thread
Product ID ros-spd-102
Price$2.95
Speedmaster Bearing Block Extension Bracket for Large Rudders Assembly
1 of 6
Product ID ros-bb-ext-lrg
Price$24.99
Speedmaster Short Transom Bracket for 40/60 Rudder Assemblies
Product ID ros-spdr-019-S
Price$8.49
Tee Bracket for Speedmaster for  Large Rudder Assemblies
1 of 2
Product ID ros-spdr-020-tb
Price$13.99
Linkage Rod Connector for 4-40 Rod
1 of 2
Product ID ose-83106
Price$2.49
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
