Speedmaster Dual Pickup Tapered Rudder Assembly
Product ID ros-spdr-011a
Price: $49.99
This SpeedMaster rudder assembly is made for large nitro and electric hulls 38" or larger. High-quality aluminum, CNC cut to tight tolerances. It has two built-in water pickups for cooling the esc and motor individually. The rudder features a breakaway brass screw in the rudder bracket to help minimize damage from the blade hitting an object while driving. Comes with basic mounting screws.
The Rudder blade measures 6 1/4" long from top to bottom. The blade is 1 1/4" wide at the top and tappers down to 7/8" wide at the bottom.
We offer this with six different brackets.
-Bracket with 1 1/8" of setback.
-Bracket with 1 5/8" of setback.
-Bracket with 2 3/8" of setback.
-Bracket with 4" of setback (pictured).
-Bracket with 5" of setback and Tee style transom mount.
-Bracket with 6" of setback and Tee style transom mount.
Setback measurement is from the transom to the front of the rudder blade. We also sell just the rudder blade itself. This can be used as a repair replacement instead of buying the entire rudder assembly.
1 Product Reviews - Average rating 5 / 5 (Show All)
Fantastic large rudder
Dan D - 18th September 2026
Picked up the 4" setback version for my M40. The original rudder I picked was undersized, causing a lot of prop walk and chine walk - poor handling overall.
This one is 2 inches deeper in the water and the cooling inlets are bigger, too. High preread more
Dual Arm Control Horn for Large Speedmaster Rudders 40/60
Product ID ros-spdr-018-da
Price$15.99
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
Speedmaster rudder water fitting 10-32 thread
Product ID ros-spd-102
Price$2.95
Speedmaster Bearing Block Extension Bracket for Large Rudders Assembly
1 of 6
Product ID ros-bb-ext-lrg
Price$24.99
Speedmaster Short Transom Bracket for 40/60 Rudder Assemblies
Product ID ros-spdr-019-S
Price$8.49
Tee Bracket for Speedmaster for  Large Rudder Assemblies
1 of 2
Product ID ros-spdr-020-tb
Price$13.99
Linkage Rod Connector for 4-40 Rod
1 of 2
Product ID ose-83106
Price$2.49
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
