Large Offset Catamaran Strut and Rudder System
Product ID tfl-502b36
In Stock 0
List Price: $89.99
Price: $69.99
Offset aluminum rudder and strut system for Catamarans with a built-in rudder water pickup. Features a nylon break-away bolt on the rudder to reduce damage when hit by submerged objects.
The mounting plate measures 30mm (1.18") wide x 24mm (.95") tall.
The leading edge of the rudder blade measures 87mm (3.42")
Includes:
- .187" (4.75mm) Flex Cable with 3/16" (4.75mm) shaft and 7mm Stuffing Tube
The system includes the following hardware:
(1) aluminum rudder
(1) aluminum strut with an installed 3/16" Lead Teflon Bearing Sleeve.
(1) 3/16" flex cable with 7mm Stainless Stuffing tube with teflon.
Requires:
Requires the customer to cut the flex cable to the required length.
Note: This is similar to tfl-502b35, but it is designed for larger hulls. Picture 3 shows the hardware on the back of a 34" (865mm) TFL Cheetah. Boat not included!
TFL Cheetah Hull : Carbon fiber with Kevlar inlay : bare hull
1 of 6
Product ID tfl-1134-hull-carbon
Price$499.99
Medium Offset Catamaran Strut and Rudder System
1 of 4
Product ID tfl-502b35
Price$59.99
3/16 (4.75mm) Strut for Large Offset Catamaran Strut System
1 of 3
Product ID tfl-502b36-a
Price$14.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
TFL Cheetah: Bare Hull w/ Decals
1 of 6
Price$349.99
TFL Cheetah with Hardware only
1 of 6
Product ID tfl-1134-hrdw
Price$599.99
TFL Cheetah : ARTR : Carbon Fiber Twin Motor Catamaran
1 of 5
Product ID tfl-1134-artr-twin-carbonfiber
Price$1,299.99
Dual Pickup Rudder Blade for TFL Genesis 900, Zonda, Popeye, Apparition or ProMarine Skater
1 of 3
Product ID ose-83248
Price$19.99
Replacement Rudder Blade for TFL 502b36
1 of 2
Product ID tfl-502b36-02
Price$14.99
