TFL 2 to 1 Transfer Case
This gearbox is designed to distribute the power from one motor into two separate drives or vice versa. Made from high-quality CNC aluminum with a metallic black finish, includes an oil fitting for easy lubrication. Never has it been easier to make your large-scale boat a twin drive system!
Hardened Gears
Ratio 1:1
Works up to 10,000 watts
Available in two options:
Circular Cable End pn# tfl-525b85-A , Diagram see picture 9 : Includes (3) Couplers pn# tfl-529b51
Square Cable End pn# tfl-525b85-B, Diagram see picture 10: Includes (2) Couplers pn# tfl-529b51
Requires:
(3) .250" Cables
**NOTE: For the Circular Cable End Version, (3) regular .250" cables will work.**
**For the Square Cable End Version, (2) regular .250" should be used for the dual output side, (1) square end is required for the single side**
Specs:
Transfer Case: See picture 6-8 for sizes
Total Weight (With 3 Couplers): 850.50g (1lb 14oz)
Total Weight (With 2 Couplers): 794g (1lb 12oz)
Total Length: 152.4mm (6")
Total Width: 127mm (5")
Total Height: 76.2mm (3")
Recommended oil: marine gear lube
Collet Coupler:
Input: Threaded Zenoah Style Conic
Cable Side: 6.35mm (.250")
