P1 Drive Part : Stern Bearing Bracket
Product ID tfl-b42515-11-v2
In Stock 4
Price: $6.95
Version 2 of this item. (SEE NOTES BELOW & Picture # 2)
Replacement part for the TFL P1 Outdrive & Scale Outboard unit.
Includes: (1) P1 Stern Bearing Bracket
See blue-lined arrow in the picture for the part this replaces.
Note:
This part changed at the end of 2020. Newer drives use a thrust bearing to help relieve pressure off of the gears. See picture three, the parts circled in green have changed. This is only if you have the older unit with the 2.5mm bearings.
- When upgrading a TFL P1 Outdrive version 1 (no thrust bearing) to a v2 style. You will need the following.
(2) pn# tfl-4x8x3 4x8x3mm Bearings
(1) pn# tfl-f4-9 Thrust bearing
(1) pn# tfl-b42515-11-v2 P1 Drive Part : Stern Bearing Bracket
IMPORTANT: Grub screw must be removed before attempting to remove Stern Bearing Bracket from the lower unit.
TFL scale outboard part: Replacement Lower Housing
1 of 2
Product ID tfl-b54210-09
Price$44.99
Bearing 4mm x 8mm x 3mm
1 of 2
Product ID tfl-4x8x3
Price$2.99
TFL P1 Drive System with 2960 Motor
1 of 6
Price$219.99
TFL Scale Outboard with sss 3660 brushless motor
1 of 7
Product ID tfl-B54210
Price$189.99
