We Accept PayPal!
We ship to Worldwide* Click here for more info.
Not logged in
Home » Motors » Brushless Motors
Leopard 3674 Motor. Special while supplies last! FREE Water Jacket with Leopard Motor Purchase! 36mm Diameter by 74mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 90%. Comes with high quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance. We offer this in 6 versions. 1400kv/rpm per volt 2.5y 1700kv/rpm per volt 2Y 1900kv/rpm per volt 3.5D 2200kv/rpm per volt 3D 2650kv/rpm per volt 2.5D 3270kv/rpm per volt 2D Specs: Magnets: neodymium Watts: 1000 with upto 1500 burst. Poles: 4 Motor Shaft: 5mm with flat spot Can Measures: 36mm diameter x 74mm long Weight: 315 Grams Mounting Screw diameter required: 3mm Bearing size: 5mm wide x 16mm od x 5mm id Mounting Holes 25mm apart for use with most 540 mounts. Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your esc connection.
OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums.
If you are using the OSE-80200 or 80210 mounts, we suggest the leo-3650 water jacket. For mounts with no rear clamp, you can use the longer leo-3665 water jacket.
« Previous | Next »
These products are recommended with items in your cart.
