OSE CNC High Rake Series Props : Stainless Steel : Reverse Rotation
Product ID cnc-HS-xx16-R
List Price: $59.99
Price: $49.99
OSE HS Series Cleaver 2 Blade Propellers in Reverse (right) rotation, machined from Stainless Steel.
CNC-machined to high tolerances for use out of the box. No modifications are needed.
 OSE CNC High Rake Stainless Steel Props - Reverse Rotation
Part Number / SizeDiameter (mm / in)Pitch (mm)Pitch (in)Drive Shaft
cnc-HS-4216-R42 mm (1.65")67.202.65"3/16"
cnc-HS-4516-R45 mm (1.77")72.002.83"3/16"
cnc-HS-4816-R48 mm (1.89")76.803.02"3/16"
cnc-HS-5216-R52 mm (2.05")83.203.28"3/16"
Specifications:
  • Pitch ratio: 1.6
  • Blades: 2
  • Material: CNC-machined stainless steel
  • Mounting: Drive dog
  • Rotation: Clockwise. ATTENTION: This is a right-hand rotation prop. These spin clockwise when viewed from the back of the boat. These are often used for twins or boats that require opposite rotation than normal. See picture 1 to view the prop's rotation.
  • When used with Zonda GT or similar power, these draw high amperage. These are for a few seconds of use for drag-style use. These will push parts hard. If you are worried about burning things up, these are NOT the props for you. Go smaller or stay stock.
1 of 2
Price$49.99
