K&S Brass Tubing 12" long (305mm)
Product ID ks-brass-tb-12
Price: $0.99
K&S Brass Tubing. These are sold in a single 12" (approx. 305 mm) length. The sizes are the outside diameter (OD).
This tubing is used when building a stuffing tube system in a boat. There are two traditional ways to build a stuffing tube using a flex cable, either with a Teflon liner installed into the brass tube OR without a Teflon liner. If you search online, you will find pros and cons to both solutions.
 K&S Brass Stuffing Tube Size Chart - 12" (305mm)
Flex Cable
Size
Without
Teflon
With
Teflon
.098" (2.50mm)8128 - 5/32"8129 - 3/16"
.130" (3.30mm)8129 - 3/16"8130 - 7/32"
.150" (3.81mm)8130 - 7/32"8131 - 1/4"
3/16" (4.75mm)8131 - 1/4"8132 - 9/32"
1/4" (6.37mm)8133 - 5/16"8134 - 11/32"
Note: All brass tubing sizes refer to outside diameter (OD). Teflon liners are sold separately. Each order includes one 12" (305mm) length of brass tubing.
 Other uses
  • 3/16" pn# 8129 is often used for 4mm solid shafts in scale(low rpm) applications.
  • 1/8" pn#8128 (1/8") and 3/16" pn#8129 (3/16") can be combined to make a propeller adapter to fit 3/16" props on a 1/8" propeller shaft.
    Notes:
  • All brass tubing sizes refer to outside diameter (OD).
  • Tubing is sold in individual 12" (305mm) lengths.
  • Teflon liners are sold separately.
  • Pictures 2 & 3 are for reference only.
  • Tubing will telescope into the next larger or smaller size. This is useful for making bushings, sleeves, or drive shafts. See pictures 2 & 3.
  • Loctite sleeve retainer glue is recommended for gluing brass tubing together.
« Previous | Next »
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
Speedmaster 21 Strut : Hydro
1 of 4
Product ID ros-spdss-001
Price$32.99
Speedmaster 21 Strut : Mono
1 of 2
Product ID ros-spdss-002
Price$32.99
OSE .098 cable with 1/8" prop shaft
Product ID ose-cable-098L
Price$24.99
Speedmaster Sport 20 Strut
1 of 3
Product ID ros-spds-005
Price$34.99
OSE .130 cable with 4mm to 1/8" stepdown prop shaft
Product ID ose-cable-1085
Price$29.99
OSE .130 reversed (right) cable with 4mm to 1/8" stepdown prop shaft
Product ID ose-cable-1085-R
Price$29.99
Speedmaster Large 3/16" (.187) Strut
Product ID ros-spds-007
Price$34.99
Linkage Rod Boots Medium
1 of 2
Product ID ose-80452
Price$2.95
Speedmaster Large 1/4" (.250) Strut
Product ID ros-spds-008
Price$34.99
TFL 1/4 Drive
1 of 4
Product ID tfl-503b98
Price$79.99
TFL 1/4 Inch Drive with skeg
1 of 4
Product ID tfl-503b98-a
Price$79.99
TFL Arenson Outdrive with 1/4 (6.35mm) Prop Shaft
1 of 4
Product ID tfl-523b43
Price$249.99
Linkage Rod Boots Large
1 of 2
Product ID ose-80454
Price$2.95
OSE .150 cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150L
Price$32.99
Speedmaster Extended 1/4" Strut
Product ID ros-spds-010-250
Price$34.95
High performance Sevan Outboard
1 of 5
Product ID bel-flex-2042
Price$169.99
OSE .150 cable with 3/16" : 3.00" long prop shaft
Product ID ose-cable-150L-xL
Price$32.99
Cable alignement T bar for Zenoha Engines
1 of 5
Product ID tfl-526b36
Price$48.99
Speedmaster 1/4" CAT: Extended Strut Assembly: Flat Bottom
Product ID ros-SPDS-012-250F
Price$44.99
Speedmaster 1/4" CAT: Extended Strut Assembly: Round Bottom
Product ID ros-SPDS-012-250R
Price$44.99
Large Offset Catamaran Strut and Rudder System
1 of 4
Product ID tfl-502b36
Price$69.99
3/16 (4.75mm) Strut for Large Offset Catamaran Strut System
1 of 3
Product ID tfl-502b36-a
Price$14.99
OSE .150 reversed (right) cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150R
Price$32.99
OSE .150 reversed (right) cable with 3/16" : 3.00" long prop shaft
Product ID ose-cable-150R-xL
Price$32.99
Speedmaster Cat Skeg Strut Assembly - Small
1 of 2
Product ID ros-spds-017-SK
Price$34.95
Speedmaster 1/4" Gas Strut and Square drive cable system
1 of 4
Product ID ros-SPDSD2-G250
Price$159.95
Speedmaster Stinger Strut
1 of 7
Product ID ros-stinger-str
Price$59.99
TFL Aluminum CNC Adjustable Strut for 3/16 (4.76mm) Shaft
1 of 3
Product ID tfl-503B23
Price$14.99
TFL Aluminum CNC Adjustable Stinger drive for 3/16 (4.76mm) shaft
1 of 2
Product ID tfl-503B70
Price$29.99
TFL Aluminum Remote Controllable 1/4 Stinger Strut
1 of 3
Product ID tfl-503B92
Price$69.95
OSE .187 (3/16") cable : drive dog : bullet nut : 3/16" prop shaft : 3.25" long
Product ID ose-cable-187-XL
Price$39.99
OSE .187 (3/16") cable with 3/16" prop shaft 3.25 long
Product ID ose-cable-1190
Price$27.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
K&S Aluminum Tubing 12" long (305mm)
1 of 3
Product ID ks-aluminum-tb-12
Price$0.99
K&S Stainless Tubing 12" long (305mm)
Product ID ks-stainless-tb-12
Price$3.50
OSE 1/4" cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290
Price$34.99
OSE 1/4" reversed (right) cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290-rev
Price$34.99
OSE 1/4" cable with 1/4" prop shaft x 30" (760mm) Long
Product ID ose-cable-1295
Price$32.99
OSE 1/4" reversed (right) cable with 1/4" prop shaft x 30" (760mm) Long
Product ID ose-cable-1295-rev
Price$32.99
Micro Strut
1 of 4
Product ID ose-83046
Price$11.95
Strut for 45 Inch (1150mm) catamaran 140mm long
1 of 3
Product ID tfl-503b85
Price$59.95
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$4.49
2mm wire drive with 4mm shaft
Product ID tfl-510B02
Price$7.99
2mm wire drive with 4mm threaded end
1 of 2
Product ID tfl-510B03
Price$7.95
Teflon Liner 20 Foot bulk package (600cm)
Product ID oct-teflon-240
Price$39.99
1/4 Adjustable Stinger Strut
1 of 6
Product ID tfl-503b82
Price$46.99
Z21 Strut for Jae-21
Product ID zip-3495
Price$24.95
OSE Stuffing tube clamp with oil fitting
1 of 2
Product ID ose-83037
Price$4.99
OSE Stuffing tube mount with oil fitting
1 of 3
Product ID ose-83010
Price$14.95
OSE Carbon Stuffing Tube Mount
1 of 2
Product ID ose-83029
Price$3.95
K&S Tubing Bender
Product ID ks-321
Price$4.57
4mm Shaft with 4mm flex cable
Product ID tfl-510b24
Price$14.99
Retaining Glue Loctite 603
Product ID mc-loc603
Price$21.99
Retaining Glue Loctite 638
Product ID mc-loc638
Price$24.99
RSX310 FE: Wood Outrigger Kit with Fiberglass Cowl (31" 787mm)
1 of 4
Product ID ml-rsx310
Price$199.99
RSX380 FE: Wood Outrigger Kit with Fiberglass Cowl (38" 965mm)
1 of 6
Product ID ml-rsx380
Price$239.99
Zipp Kits JAE 21FE v2: Wood Outrigger Kit  (33" 838mm)
Product ID zip-6513
Price$119.99
Speedmaster Bushing 3/16" for Sport 20 & 21 Style Strut
Product ID ros-spds-014-bsf
Price$5.95
Speedmaster Bushing 1/4" for Large Struts
Product ID ros-spds-015-bsf
Price$5.95
