Leopard 3650 Motor
Product ID leo-3650
List Price: $56.99
Price: $44.95
Leopard 3650 brushless motor
36 mm diameter by 50 mm long brushless motor by Leopard Power. Hand-wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance.
We now have these in both 1/8" & 5mm motor shafts.
We offer these from 1350Kv to 3900Kv (rpm/volt)
Specs:
Magnets: neodymium
Watts: 600 with up to 1200 burst.
Poles: 4
Motor Shaft: 1/8"(3.17mm) or 5mm
Can Measures: 36mm diameter x 50mm long
Weight: 185 Grams
Mounting Screw diameter required: 3mm
Bearing size: 5mm wide x 16mm OD x 5mm ID
Flat Spot on shaft for tightening coupler screw to. Mounting holes 25 mm apart for use with most 540 mounts.
Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your ESC connection.
OSE suggests 20,000-35,000 total rpm for boats. We suggest that most Fast Electric Boaters should run in the 25,000 RPM range for Sport Boating or the 30,000 RPM range for racing. These are only guidelines; if you do not have the knowledge to choose the correct motor, please consult other members of the RC fast electric boating community or us first. Either at a local club or on our OSE Forums.
Works with OSE-80230 Water Cooled Motor Mount
3 Product Reviews - Average rating 5 / 5 (Show All)
Good
Elvis white - 26th March 2024
The 3650 might be underated
Patrick Smith - 19th June 2022
I was curious to put some extreme load on the 3650 4550kv and datalog the results to see what the motor is capable of.
Let just say I had the motor up to 4200 watts. 316amps peak. At 316amps over 45000 rpm. On 4s, I ran it with the load for 3.5 secondsread more
Good motor - go for it
Matthew Norris - 22nd December 2016
I've had this motor for a few months now and like it a lot. Its been emerged in water a few times and still works good. 6mm connectors it comes included: fantastic. Tight fit.
Torque seems really good.
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
T-Jet Small Jet Drive by TFL
1 of 8
Product ID tfl-b54253-a
Price$69.99
T-Jet Small Jet Drive V2 w/ Reverse Hood
1 of 9
Product ID tfl-B54254
Price$99.99
Adjustable Motor Mount for 28/36mm Motors
1 of 3
Product ID ose-80080-c
Price$10.95
Water jacket 36 x 45mm long
Product ID tfl-532b40
Price$13.99
Adjustable Water Cooled Mount for 28/36mm Motors
1 of 4
Product ID ose-80230-b
Price$12.95
OSE Raider 6s 90amp Esc with Ec5 connectors
1 of 2
Product ID ose-R-90
Price$49.99
Delta Force 26: Bare Hull (25.5" 648mm)
1 of 4
Product ID df-delta-26
Price$139.99
Leopard 3640 Motor Water Jacket
Product ID leo-3640-jacket
Price$13.00
Leopard 3650 Motor Water Jacket
Product ID leo-3650-jacket
Price$13.00
