Leopard 3650 X2 Motor
Product ID leo-3650-X2
Price: $59.95
Leopard 3650 X2 brushless motor.
36mm Diameter by 50mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 90%. Comes with high quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance.
We offer this in 2 versions.
3060kv and 3900kv
Specs:
Magnets: neodymium
Watts: 600 with upto 1200 burst.
Poles: 4
Motor Shaft: 5mm
Can Measures: 36mm diameter. See picture #4 for size specifications.
Weight: 190 Grams
 Mounting Screw diameter required: 3mm
Bearing size: 5mm inner diameter x 14mm outside diameter x 5mm wide
Flat Spot on shaft for tightening coupler screw to.Mounting Holes 25mm apart for use with most 540 mounts.
 Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your esc connection.
OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums.
Works with OSE-80230 Water Cooled Motor Mount
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
T-Jet Small Jet Drive by TFL
1 of 8
Product ID tfl-b54253-a
Price$69.99
T-Jet Small Jet Drive V2 w/ Reverse Hood
1 of 9
Product ID tfl-B54254
Price$99.99
Adjustable Motor Mount for 28/36mm Motors
1 of 3
Product ID ose-80080-c
Price$10.95
Leopard 3640 Motor Water Jacket
Product ID leo-3640-jacket
Price$13.00
Leopard 3650 Motor Water Jacket
Product ID leo-3650-jacket
Price$13.00
