Leopard 3660 X2 Motor
Product ID leo-3660-x2
Price: $69.95
Leopard 3660 X2 Motor.
36 mm diameter by 60 mm long brushless motor by Leopard Power. Hand-wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance.
5mm motor shafts.
We offer this in 2 versions.
2380kv and 3180kv
Specs:
Magnets: neodymium
Watts: 800 with up to 1300 burst.
Poles: 4
Motor Shaft: 5mm
Can Measures: 36mm diameter. See picture #4 for size specifications.
Weight: 250 Grams
 Mounting Screw diameter required: 3mm
Bearing size: 5mm inner diameter x 14mm outside diameter x 5mm wide
Flat Spot on shaft for tightening coupler screw to.Mounting Holes 25mm apart for use with most 540 mounts.
Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your esc connection.
 Front- and rear-vented end caps for additional cooling.
OSE suggests 20,000-35,000 total rpm for boats. We suggest that most Fast Electric Boaters should run in the 25,000 RPM range for Sport Boating or the 30,000 RPM range for racing. These are only guidelines; if you do not have the knowledge to choose the correct motor, please consult other members of the RC fast electric boating community or us first. Either at a local club or on our OSE Forums.
Works with OSE-80230 Water Cooled Motor Mount
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
T-Jet Small Jet Drive by TFL
1 of 8
Product ID tfl-b54253-a
Price$69.99
T-Jet Small Jet Drive V2 w/ Reverse Hood
1 of 9
Product ID tfl-B54254
Price$99.99
Adjustable Motor Mount for 28/36mm Motors
1 of 3
Product ID ose-80080-c
Price$10.95
Leopard 3640 Motor Water Jacket
Product ID leo-3640-jacket
Price$13.00
Leopard 3650 Motor Water Jacket
Product ID leo-3650-jacket
Price$13.00
