Multi Function Generation 3 programmer for the Seaking Pro 120A & 160A ESC.
This multi-function program box is for programming HOBBYWING brushless ESCs. Its friendly LCD interface makes ESC programming easy and quick. With a PC, you can upgrade ESC firmware and further adjust ESC parameters online. Besides, it’s compact, portable and very applicable for field use. Thanks to built-in OTA programming feature through Bluetooth™, you can now use this device with IOS devices.
This multifunciton LCD program box is applicable for the following HOBBYWING products:
Platinum series of brushless aircraft ESCs, XeRun & EzRun MAX series (V2.0 and later), Platinum and SEAKING PRO series. This device also work with some ESC of QUICRUN series.
Specifications
Size:5.24 x 3.44 x 1.75 inWeight:85gInput Voltage: DC 5V—12.6V(a separate battery is needed for powering this program box when ESC has no built-in/external BEC)
Download:
NOTE: Will not work with the Seaking v4 series.
