Neu 2215 MotorSpecifications:Click for Neu Motor Chart The Neu 2215 motor is built to order, they take approx 4 weeks to build. If you don't see the option you need please email us. Specs: KV Options: 1440KV, 1020KV, 750KV Weight: 24.8 Ounces Approx dimensions, 3.3" Length x 2.5" diameterInternal front fan.Mounting Screw diameter required: 4mm Mounting Holes 30mm apart. Poles: 4 The picture is an example of a finned case.
Requires:4mm Mounting Screws and connectors.
If you don't see the motor wind listed you need or need special options, we can special order from the entire Neu Motors line up. Contact us for more details.
