SSS 3660 V2 Brushless Motor
Product ID tfl-sss-3660-v2
Price: $54.99
SSS 3660 V2 brushless motor.
Special while supplies last! Water Jacket with TFL SSS Motor Purchase!
36mm Diameter by 60mm Long Brushless Motor by TFL Racing. Hand wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Includes end bells that are assembled with screws for both strength and ease of maintenance.
Vented endbell and front mounting plate for additional air cooling.
Specs:
Magnets: neodymium
Watts: 1800
Poles: 4
Motor Shaft: 5mm with a flat spot
Can Measures: 36mm diameter x 60mm long
Weight: 245 Grams
Mounting screw diameter required: 3mm
Mounting Holes 25mm apart for use with most 540 mounts.
Connectors: 6mm Male Bullet connectors preinstalled onto the motor.
OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums.
3 Product Reviews - Average rating 5 / 5 (Show All)
Good fit for Blackjack 24 V2
Dan D - 18th September 2026
I picked up the 2700kV version for my Blackjack 24 V2 and 4S. The 3200kV 3660 I tried at first was a little too spicy for 4S. This one slots in perfectly where it flirts with 60MPH on 4S. Pushing it a little hard and the temps stay sane as well. Paired itread more
Awesome motor
Ozzy - 23rd January 2024
I just put this 3660 2700kv sss motor in my r4 outrigger.wow. my first run I got 60mph on 4s. The motor was smooth, quiet and stayed cool. Never got over 80degrees, though it is winter and the water is cold. Really love this motor and the price is great, read more
Great motor
Alex N - 21st October 2021
I run this in my Blackjack 24 (2700kv on 4S) and I have had very good luck running it on the OSE 150A ESC. Stock motor is a 2000kv 3650 and this slots nicely into it's spot. I run it on 3S for bashing around and 4S for speed runs (53mph so far). Great relread more
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
T-Jet Small Jet Drive V2 w/ Reverse Hood
1 of 9
Product ID tfl-B54254
Price$99.99
Adjustable Motor Mount for 28/36mm Motors
1 of 3
Product ID ose-80080-c
Price$10.95
TFL Scale Outboard with sss 3660 brushless motor
1 of 7
Product ID tfl-B54210
Price$189.99
TFL Integrated Drive System
1 of 6
Product ID tfl-B42530
Price$89.99
